Outlook Country Codes & Dialing
1 replies · 2,208 views · Started 18 December 2001
Problem is that my data within outlook contains the +44 Country code for all my contacts.
When I sync with 9210 all the +44 carried forward meaning that when I go to dial error dialing due to +44 and 0 being present at beginning of number.
Suggestions please.
Steve
Took me a while to figure this one out. Had the problem with my last PDA and that was a Pocket PC. What I had to do was go through all my contacts in outlook and remove the 0 from the area code. The dialing rules are used to add the zero if the call is not international.
So in Outlook, the number appears as +44 (1234) 567890
This dials correctly on the Nokia as well. It dials with the +44, but I get charged the same rate, so I guess this does not matter.
Zuber<font size=-1>[ This Message was edited by Zuber on 2001-12-19 1510 ]</font>
