hello.. does leaving my bluetooth on??
8 replies · 1,685 views · Started 21 October 2002
There is a difference when it is on but its so small you cannot notice! Even when the phone is connected! However, when there is activity like transfer of files and data, the battery gets drained more easily!
The OS itslef supports .wav and .midi. Its supports rng but this is just lame beep sounds for ringtones!
There is 3rd party software that can play mp3s as well! There is no limitation on the Platform side!
ic,
do u know the ".au" format works to,
it's just like the quality of a wav file, but much smaller,
thanks again.... 😃
I havent tried it but I think its not possible! At least there is nothing mentioning au at the nokia site!
yup,
it is possible,
i have one in my phone and i use it as my ringtone,
do u happen to know a ".amr" encoder??
i only have a decoder,
thanks......
Yup.. it will alsp drain more if you on your vibrating Alert ON. You can try it and Off it and compare the difference 😉 oh yeah.. and also you keep on playing with your phone while the backlight is always on.
[quote="MaleBuffy"]There is a difference when it is on but its so small you cannot notice! Even when the phone is connected! However, when there is activity like transfer of files and data, the battery gets drained more easily![/quote]
