Need a Backup file
3 replies · 1,827 views · Started 19 January 2005
I have a problem, that is, all Java applications have the same disktop Icon (computer Icon) but the applications work very good. While these Java apllications have their true icons in the JAVA Ctrl menu. This problem occured after I formatted my C deive since my phone was dead and I had to format it. I reinstalled my firmware without any solution. Does any one has a solution to retrieve Java application icons to their original ones?
I think I need a backup file of a phone that does not have such problem to restore it on my phone to fix my system files then after that I rearrange my phone again and reinstall my applications. I need this backup file from any body who does not have this problem regrdless the applications he has installed on his mobile.
Thank you in advance.
amindanial wrote:Thank you very much for your help.
i`m glad to do any thing for any one if u still have problems try pressing *+# and power ON the fone FORMAT
