6630 -> unlock 3g (dual) to GSM mode -> tutorial
37 replies · 32,669 views · Started 19 January 2005
Net Monitor?
Correct me if I am wrong, but with DCT-4 and BB5 (6630) handsets, doesn't the phone have to have Nokia test firmware installed to have the Net Monitor feature enabled?
Only recently have tools to read unencrypted firmware from DCT-4 phones been available, and as far as I am aware the tools and algorithms to re-encrypt the flash files haven't been released, although a few people on GSM Forum claim to have cracked it.
Are things different with the 6630 (BB5)? Can Net Monitor be added without messing about with the firmware?
Never mind all the bollocks I wrote in the last post, the program is a .sis file called OperatorFtdwk39v7.sis and there's a link to it in some italian forum here: http://www.nokiaworld.it
I'm still waiting for the registration confirmation email to arrive User posted image
Never fear, I'll post a link soon as I get it to save all you lot faffing about.
fannypad wrote:Never fear, I'll post a link soon as I get it to save all you lot faffing about.
a quick word of advice mate, check the rules of this forum, I am sure this app has been requested here before (quick search the forums) and I think the mods were a little "unimpressed" with the link.
Cheers
DK
Furry muff. Will have to stick it up somewhere else.
Any chance of a pm with a pointer? No activation email from the italian site yet.
Never mind, found it elsewhere.
Anyway, on mine most of the tests described in the .doc manual that came with it are missing, i.e. scrolling through using the up/down keys, it skips straight from 10.6 to 41.1, then from 48.2 to 81.1 with nothing in between.
Is it the same on yours? Can't see mention of a way of enabling the rest, which is a shame as there's some juicy tidbits to be had.
there are three type of displays (as per the manual)
* Execute menus --> allows you to change values
* Info Menus --> info cant change
* Data Menu (??) --> same as above
Side keys on my 6630 jump menus, up down allow you to navigate sub menus of a group. IE
SIDE KEYS:
1.1 -> 5.1 -> 6.1 etc
UP DOWN:
1.1 -> 1.2 -> 1.3 etc
Not all the menus mentioned in the manual are accessable on the 6630 as the manual is a generic doc for 2.5G and 3G networks.
Cheers
DK
dakku wrote:there are three type of displays (as per the manual)
SIDE KEYS:
UP DOWN:
Yes, I kind of gathered that 😉
What I wanted to know was does yours skip straight from 10.6 to 41.1, then from 48.2 to 81.1 with nothing in between? I.e. if I type 6101 in the Change Display box it gives a "No such test display" error.
fannypad wrote:Yes, I kind of gathered that 😉
yes you can skip between the menus that are AVAILABLE. to do this you need:
options -> change display -> (insert menu number.group_id )
ie: 4801
but you cannot skip to 4803 as this menu is not available on the 6630.
Adios
daywalker wrote:seen it and replied! 😃
😃 😃 😃 finally gsm only...no more problems with the f****** vodafone.
Tknx a lot, i owe u one. 😉
Is there any way to use this program vice verse. In my country 3G is in testing phase and it is free for the moment but because of that 6630 won't log on it. (It's something like when 3G is in testing phase it sends code to the phone not to connect to it.). So im thinking of forcing connection.
da_bar wrote:Is there any way to use this program vice verse. In my country 3G is in testing phase and it is free for the moment but because of that 6630 won't log on it. (It's something like when 3G is in testing phase it sends code to the phone not to connect to it.). So im thinking of forcing connection.
yes ofcourse, follow my tutorial (1st post in the thread) and instead of typing 1, just type 2. which stands for WCDMA. This will make your phone work only in 3g mode.
The_Boss_PT wrote:😃 😃 😃 finally gsm only...no more problems with the f****** vodafone.
no probs anytime! :icon14:
More likly that your network wont allow you to log into it BECAUSE its still in testing phase. Forcing it into 3G will most likly mean that your phone will still not connect to it and it wont bother looking for a 2G signal resulting in no signal.
I've sent PMs to three different people in this thread regarding a certain application 😉 but got no responses. So make sure you check your PMs!
That's true, I've tested in both way (forced GSM, forced UMTS) it works just perfect. 😊
Rough translation of instructions to swedish:
Installera OperatorFtdwk39v7.sis p� din 6630.
Starta det (kommer att heta 'Test' p� telefonen).
Bl�ddra h�ger tills du kommer till meny 81.1
Tryck 'Val'
V�lj 'Execute'
Mata in '1' f�r att s�tta telefonen i GSM-only mode.
Telefonen startar nu om ett par g�nger.
Sdw wrote:Rough translation of instructions to swedish:
Tryck 'Val'
V�lj 'Execute'
You can find full netmonitor guide right > here <
On English off course
Cheers
www.symbian-freak.com
there is something i dont get, doesnt the 6630 auto switch from 3g to normal? Im thinking of getting the o2 version and using my orange pas-as-you-go in there, would i need to use this little app to get it working?
