vnes work amazing on my 6630
13 replies · 4,590 views · Started 20 January 2005
If you think Vnes is good, try Picodrive 😉
Smooth as Kiera Knightley's funbags. I'm halfway through replaying Sonic on it and loving every minute. Who needs slow java games when you've got thousands of quality Mega Drive roms to choose from?
fannypad wrote:If you think Vnes is good, try Picodrive 😉
Haven't tried this before so I'll try and install it. Where do you download the megadrive roms from?
neatheyc wrote:Haven't tried this before so I'll try and install it. Where do you download the megadrive roms from?
Just put "megadrive roms" in Google, you'll get a ton of sites. They're only tiny files.
i tried using it and it wont detect the roms...where do i put the roms at??
Put em anywhere on the memory card. When you go to load a rom a browser will pop up, and you can browser the card and select the rom from there.
And as far as I know there's only one version of Picodrive around that works on the 6630; it's the new version modified with files from a slightly older version in order to work.
fannypad wrote:Put em anywhere on the memory card. When you go to load a rom a browser will pop up, and you can browser the card and select the rom from there.
I tried to get picodrive to work earlier but it says its an unsupported file format. I don't think I downloaded the right one as there were 2 .exe files that I was told to copy to my device and run. One was the phone key settings and the other the emulator.
So I guess I don't have the right one as .exe files don't work on phones?
neatheyc wrote:I tried to get picodrive to work earlier but it says its an unsupported file format. I don't think I downloaded the right one as there were 2 .exe files that I was told to copy to my device and run. One was the phone key settings and the other the emulator.
BUt I've just found picodrive60.sis so I'll give that a wirl and see how I go!!
Sonic here we come..........maybe.
neatheyc wrote:BUt I've just found picodrive60.sis so I'll give that a wirl and see how I go!!
Manage to install a version of this ok. But when I start it, at first it just flashes up on the screen and then goes away. I start it again and its got a blank screen. The only option is to Exit?
Yeah, same here.
I guess we got the old version not modified for 6630.
I'll keep looking -
Also put 'megadrive roms' into google and got 5000000000 more pages of forums and links to pages asking for megadrive roms - ended up going round and round and up me own arse! 😊
willbrady wrote:Also put 'megadrive roms' into google and got 5000000000 more pages of forums and links to pages asking for megadrive roms - ended up going round and round and up me own arse! 😊
The very first site in the search results has a whole bunch of them. 😉
Put in megadrive roms and hit the "I'm feeling lucky" button, but don't put the phrase in quotations when you search.
