hello
I installed the theme downloaded from the sendo page...
and i see that it is already installed by checking the program manager in Tools..
and when i go to Tools > Settings > Phone > Display
and i click on theme... i cannot choose anything..other than "Sendo"
up and down..left and right...no luck...
and help?
Have you made sure you have the latest firmware that supports additional themes?
Check on your phone by dialling *#0000#
If not check your sales pack number (SPN) on the label behind the battery above "Made in netherlands" and install the latest matching version from http://www.sendo.com/smartphones/downloads.asp
Theme support was added in firmware version 50C (1.56.2.2) - any older firmware will not allow you to change themes.
oh thanks
no wonder..
i am only x1.30.16.1
