How do you use yours? (keyboard that is)
5 replies · 1,820 views · Started 20 January 2005
Just wondering as on my 9210 I came up with a variation on touch typing using the index and middle fingers on both hands to enable fast typing, which involved sliding my finger across to the nearby keys when they were next to each other to allow swifter input. The benefits of that lovely keyboard.
I've now managed to adapt this touch-typing style to the 9500 apart from the ability to slide my fingers, the keyboard doesn't really allow that. But typing speed is up and the ease of use is really kicking in.
So how do you type on yours, thumbs? index fingers? Any tips and tricks?
Thumbs. My 9300 has a smaller keyboard than the 9500, so 4 finger typing isn't really comfortable, two works well though. However, I feel the size and weight makes it ideal for thumb typing.
Btw, I wanted to ask, where is your apostrophe sign located? On my Scandinavian keyboard layout it is under the 1 key - which makes it very uncomfortable to hit when I thumb type...
I use as many fingers as I can, which usually results in a garble... 😞 Give me the Revo keyboard, please...
Raven wrote:Btw, I wanted to ask, where is your apostrophe sign located? On my Scandinavian keyboard layout it is under the 1 key - which makes it very uncomfortable to hit when I thumb type...
Next to the enter-key, sharing with the @-sign.
http://www.expansys.com/zoompic.asp?type=item&code=111586
Right, thanks. I thought the weird placement of the apostrophe had to do with my layout only, that's where my � letter is... :frown:
I use it with 4 fingers if it's layed out on a table or something, but if I hold it "on the go" (while standing for example) I use my thumbs
