Is there any program like MiniGPS for the 9500?
Thanks.
GPS for the 9500?
What does that thread have to do with GPS for the 9500?? :con?
I can see you don't know what is MiniGPS program.
It has nothing like real GPS !
It is like that celltrack, it use GSM network not GPS to locate your position.
http://www.psiloc.com/index.html?action=ShowArticleItem&ida=154
I did know what MiniGPS is FYI, I just couldn't link it with the thread you linked here.
And quite frankly I still can't, because he asks if an app like MiniGPS exists, and the thread you linked to doesn't answer that.
MiniGPS is not (yet) available for the 9500, and AFAIK nor any other similar apps...
Delta737 wrote:I did know what MiniGPS is FYI, I just couldn't link it with the thread you linked here.
And quite frankly I still can't, because he asks if an app like MiniGPS exists, and the thread you linked to doesn't answer that.MiniGPS is not (yet) available for the 9500, and AFAIK nor any other similar apps...
Yes but that link tells that Arjen has made similar program for 9210, it's OPL and 9500 has its own OPL runtime so it should work on 9500, like many 9210 OPL software, that I have been tested, worked.
Arjen writes that hi put it on his website for download, so I think it colud be the solution.
