Nokia 6630...Problem
1 replies · 1,775 views · Started 20 January 2005
I have been having problems connecting N6630 to computer and sending text messages. I can do everything else like transfer new apps, files and new contacts...but i cant send text messages through computer...Is there something i am not doing correctaly because it cant see my phone on the USB cable even though everything else works.
Regards
Chris 😡
The Nokia PC Suite's text messaging application works with those Nokia phones which have a corresponding piece of software on the phone-side. The 6630 and other so called Series 60 Platform based phones do not have that required software, so that PC Suite app does not work with such phones (only other Nokia phones such as those based on Series 40).
It would be more friendly, if PC Suite as it detects which phone is connected, disabled features and apps that do not work with such phones.
The compatibility matrix/tables on http://www.nokia.com/pcsuite will detail what works with what (and what doesn't): http://www.nokia.com/nokia/0,,54698,00.html#apps
If you run Windows XP, you can also try the Microsoft SMS Sender app (it works by using the phone as regular modem and AT commands to send SMS):
http://www.microsoft.com/downloads/details.aspx?FamilyID=06a4f997-7f69-4891-8929-37b9041924a2&displaylang=en
