hi Every1 I ve joined now and I gotta fresh question.
Please Check outta the Pictures...
Outdoor
It looks like normal fo 1,3MP but under da expections
Indoor Thats da way it sucks
Is it related to da Firmware version cuz u can see da diffrence? (3,45.111 i got)
2nd photo is under da spotlights in a room. (Be sure that they r enough )
Have you tried taking pictures WITHOUT FLASH with ANY digital camera in a room and see what the result is?
UA
it took me 4sec. in "noiseware" to get rid of alot of the noise... 😊 here is the result: 😉
The better the picture on the phone the worse indoor pictures will be cameras have never been good at indoor shots under low light.
If you make the picture smaller and clean up the noise they usually loook fairly decent.
Very good 😊
Dude can you tell me which application you used for noise?
Please..
Regards
technod wrote:Very good 😊
Please..Regards
I use Noiseaware trail version, found at http://www.imagenomic.com 😊
Get the nokia camera flash, makes all the difference!!
