How I get a list of currently running programs?
Is there anything like a task manager, where I can end programs running in the background?
S.
S.
simonmcc wrote:How I get a list of currently running programs?Is there anything like a task manager, where I can end programs running in the background?
S.
If a program is mis-behaving, then pressing the "C" key instead of the select key will abort the program.
There are commercial programs that do much more than this, listing a lot more about what is going on in the handset - one such example is AppMan.
I will amend the FAQ to add this info - thanks!
pk
Excellent, thanks for that!!
Any other useful key tricks while we're on the subject?
S.
if a program crashes, the task manager of nokia is not able to kill the program.
another good taskmanager is: psiloc task manager http://www.psiloc.com/?id=160 [but shareware :icon13:]
You might want to try switcher (freeware) as a task manager.
http://www.ki-ag.de/pages/tech/switcher.html
