IMAP email problem with mac.com on Nokia 7650
3 replies · 2,399 views · Started 21 October 2002
I just bought a Nokia 7650 which should give me access to my ".Mac" IMAP email (http://www.mac.com).
However I can't access it at all (I get an error msg saying that the mailbox is disconnected or something like that...), and I am sure that the GPRS settings are correct on the phone since my operator sent'em to me. Also the same GPRS settings used to work to get access to my email using IMAP4 on my SE T68i.
Anyone has a clue? Please 😊
Thanks, Arnaud
The problem is mainly resolved: I'm used to have incoming and outgoing servers the other way around, so I just had to inverse'em. BUT even if I can check and receive I still can't send!
(I am on Swisscom using GPRS)
