ppp over bluetooth
3 replies · 2,083 views · Started 22 January 2005
Is there any way to connect the X to a PC via bluetooth, and use that as a TCP/IP connection?
Basically - is there any way of connecting to the internet using a home network as a gateway?
I have looked through all the menu options I can find, and can't see how to do this
Simon
simonmcc wrote:Is there any way to connect the X to a PC via bluetooth, and use that as a TCP/IP connection?
Simon
Create new Access point with Data bearer GPRS and leave all other fields it blank. Now connect your Sendo X to mRouter with Bluetooth or IrDa. And now you can use this Access point as gateway to PC.
(but some apps do not support this type of connection)
psintak wrote:Create new Access point with Data bearer GPRS and leave all other fields it blank. Now connect your Sendo X to mRouter with Bluetooth or IrDa. And now you can use this Access point as gateway to PC.
I've got that *half* working.
For example, in opera, if I connect to an online webpage, it brings up the connection screen, and I select my test connection.
The little 'G' flashes for a few seconds and then turns to [G] with a square round it, which I assume it means the connection is established.
The selected page loads from the internet, as expected, but then the connection is disonnected, no [G] or 'G'
Similar behavior in avantgo
What am I doing wrong?
Any ideas??
Simon
simonmcc wrote:I've got that *half* working.
Any ideas??
Simon
After some flashes of G, it should not turn to [G] - it means that you are connected with GPRS, but you have to be connected with your PC connection.
Try some other program (not only Opera) if it works ...
