Hi every body
- could i install another operating system on my Motorola A295 ?
- If Yes From where i Can download the Operating System ?
- To be able to Send Unicode Directly you need to Make Sure that you SMS
Setting In Control Panel (Connections) (Massege Account) Character Set is
Using UCS2 and not 7bit
- When I go there I cant found this Option (Using UCS2)
so any one can help ?
