nokia 7650 mem compress!
10 replies · 3,195 views · Started 21 October 2002
Is there a way to compress the 4 mb in drive c: of nokia 7650 with software? do you think about that? i dont think it is impossible!! 😊
it will be great if we can do that but i don't think it's possible because its not 😃 harddisk
[quote="mikeprice53"]Under settings in the new version[/quote]
i have the latest registered version there is no such option.u mean Memory task must be on?
[quote="Global moderator"][quote="mikeprice53"]Under settings in the new version[/quote]
i have the latest registered version there is no such option.u mean Memory task must be on?[/quote]
I think i found it..Thank u..
I must press ABC and menu key
I think if you reboot your phone you can reclaim more memory rather than using seleq memory compression 😃
i don't see how you can reclaim memory by turning the phone off?
memory compression by seleQ is pretty good, i think 😊
