DSS-25 Unlock with Davinci?
2 replies · 2,595 views · Started 23 January 2005
Anybody managed to get the davinciteam unlock software to work through the stock DSS-25 USB cradle on a P900? The software claims it will; yet I can't get it to work! Just keeps waiting for me to power the phone to discover it (phone powers up, but no comms).
Currently have an unlock credit that I can't use!
philhoward wrote:Anybody managed to get the davinciteam unlock software to work through the stock DSS-25 USB cradle on a P900? The software claims it will; yet I can't get it to work! Just keeps waiting for me to power the phone to discover it (phone powers up, but no comms).
Hi Phil,
Just had this problem last week myself. After lots of experimenting into the early hours - here is how you do it.
Make sure that you DESELECT (ie untick) the USB com port from within the PC sync properties down in the system tray - so the sync software will not hijack the com port. Then after you put the P910 in the dock and the Davinci software asks you to press the power on button - make sure you only press it momentarily - not even long enough to normally switch the phone on.
Hopefully this should sort you out.
Regards, Steve 😊
Many Thanks for the reply, Steve...sadly I got the unlocked locally instead and sold it on about 4 months ago instead!
