Can you delete some of the built in profiles?
2 replies · 1,836 views · Started 24 January 2005
Hey all,
I was wondering if there was a way to delete some of the built in profiles from the N-Gage QD. I only use normal, silent, and offline. The other ones just make the power button menu longer, so I was wondering if there was a way to delete them. I know there's not a built in way, but I'm pretty comfortable with the N-Gage file system, so I don't mind hacking it.
Thanks!
They are defined in ROM (Read-Only Memory) so can't be deleted/removed with any amount of file system hacking.
