Can not get it to work. Do I need to install anything extra or what do I need to do?
HTTPS connection in Nokia 6630?
All you should need to do is: Nothing. It works for me by just typing "https://..." for the URL in the browser.
Are you using a WAP or Internet Access Point? Is your operator allowing https through their gateways/proxies?
N/A wrote:All you should need to do is: Nothing. It works for me by just typing "https://..." for the URL in the browser.Are you using a WAP or Internet Access Point? Is your operator allowing https through their gateways/proxies?
Thank you
I am using an Internet Access Point. (3G)
Tried to connect to https://support.nokia.com/ but it did not work.
Do not get an error message the phone is just thinking but nothing happens.
Tried both port 8080 and 9201 without any results
Works for me with a regular Internet access point and any https://... site (including those you posted in your original message + a couple of others) and the browser (Web) that comes on my 6630.
