Does anyone has movies that is off the correct size for 7710?
Movies for 7710?
Powerpuff wrote:Does anyone has movies that is off the correct size for 7710?
wht r u askng 4??????
thrz no sch thng as crrct size of a movie.
if ur askng bout formats thn d 7710 cn ply 3gp & rm moveis.
I think he means the correct resolution...
i think you should check out Mobile Media maker. its a fantastic prog that supports nokia 7710.it converts the movie straight from the DVD disc.
Delta737 wrote:I think he means the correct resolution...
resolution, videos only have bitrates 😡
Hey that's cool, didn't know the 7710 played movies....sounds sweet and I guess it would be better than a portable dvd player because the battery life is better right? How do you get the movie on there? Is it just a matter of downloading onto PC, plugging into USB port from the phone? Do these accessories come with the phone?
