I own a nokia 9500, which i use in greek language. Sometimes, I need to type a word in english (for example, a email).....How can I change the typing to english, and then turn back to greek??? :con?
I m waiting for your help...
thank you in advance...
Change typing in 9500???
Hello
I am for the time being only intending to buy the 9500, it actually depends on a positive answer to your reply, because I use several languages, and writing without an accent is not very decent or taking notes in my Greek class is also impossible😊
I have found a wonderful software, this is what we actually would need; unfortunately it is currently only available for the 9210 (which I am still using at present but obviously shan't buy it for the remaining weeks). I hope InterKey will soon do an update for its use on 9500. I emailed them ([email protected]) to know when it would happen, the system promised a reply in 2-3 working days. If I receive an answer, I shall post it here.
gkourias wrote:Hi,
Press both the shift buttons and the language will change to english
