hmm, i have new noki 6260 and i have one big problem with internet connection.
I can't connet to anyone messenger. I try stICQ, AGILE, Cmessenger...
Phone just show me "connecting ..." and don't work. After any time show me error: " java.lang.NullPointerException"
My web browser work great.
Can you help me somebody?
my operator is T-mobile USA
Make sure you have the correct Internet Access Point settings for T-Mobile USA:
http://www.nokiausa.com/support/settings/1,1921,,00.html
Make sure you have configured these applications (Options > Settings or however each app is configured) to use that particular access point.
Check also with T-Mobile customer service that you have a plan/subscription that allows you to use GPRS Internet access (and if they need to enable it in their systems somehow, that they have done so, too).
my setings id well. Internet conection work great. I can brows on iternet web pages. Just i can't connet to messengers. T-mobile not support nokia 6260 yet. Setings is form nokia 6600 from www.nokiausa.com. I try call to technical support T-mobile, but nobody know help me.
