now i have the money to buy one of them, so which one do you guys recommend me getting? which one would be useful??
card reader or bluetooth
BT is great for using the supplied pc suite software, and some apps can only be installed using the pc suite (for some reason :con? ) but if you are into transferring large files to your phone, mp3s etc, then get the card reader. its sooooo much quicker! 😊
i would recommend bluetooth.. if the 7610 would have had a hot swap mmc slot like the 6630 then the card reader would be a better choice. BT is wireless.. u can do loads of things with it while a card-reader is almost the same price and BT is wireless, it might be slow but it allows freedom of wires! i personally use the data cable and BT
