pls help chinese text input
7 replies · 3,641 views · Started 25 January 2005
I'm sorry but I don't think you can. IIRC if you have a chinese version, it's called the P908. So basically, you just have the wrong phone...
Delta737 wrote:I'm sorry but I don't think you can. IIRC if you have a chinese version, it's called the P908. So basically, you just have the wrong phone...
ok, thanks Delta737 :icon14:
Not sure. IIRC it doesn't help, but I could be mistaking. Do a search, you're not the first one with such questions here 😃
Wirelessly posted (SonyEricssonP900/R101 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Delta737 wrote:Not sure. IIRC it doesn't help, but I could be mistaking. Do a search, you're not the first one with such questions here 😃
HOLD ON! anybody who says chinese can not be removed is wrong(even sony erricson helpdesk). How can I be sure? because I had the same problem and now the only chinese I got is on the flip. How did I do that? I didnt. The tech who I bought the cellphone did and he discovered it by accident. I am not sure what he did, I think he burned the european version or something, but THERE IS A WAY!
ok, coz my friend told me that i should upgrade it because that's the only way, he said.. but i've already talk to the owner that i purchase the wrong fone and he said he will cahnge. :icon14:
thanks guys 😃
