Does anyone have any experience to transfer images from EyeQ camera via IR to the PC (have a IR port) directly instead to load first to 9210 and thereafter load to PC.
If I try I can on PC have contactto the camera but not se any way to load the pictures.
Hope for some help to save time!
Blacking
It depends on your computer's OS. If you're running Windows 2000 or XP, I believe there's native support for the IRTranP protocol used by the 9210 & camera. If you're running something else, though,, I guess you'd need some sort of third-party program. Anyone aware of one for Win 98 or Linux?
I`m using Windows 2000 in my notebook and dont detect any problem. To send pictures you just need to send them with the EyeCam, activating the infrared transmition. When PC receive the pictures that you selected to transmit, and it stores them in your Pictures Gallery.
Thanks for replying BUT
I run Windows 98 and dont know witch third party program there can help to catch pictures, my Photo Magic dosen�t
Blacking
