The font size in the contacts details is too small or too thin compared to font for names or headers which are in bold type.
Does anyone know of a way too change the details to a bolder type/font
so they are easier to read.
Thankz
Font size in Contacts
Bad Problem hope we can find a way to change the FONT
The font in my contacts are fine - its larger than the font in my 6510 and other phones...
I very much doubt there is a way of changing the size or formatting the font itself.
Unless there will be a new software designed to do so - if you have time on your hands, you could try designing a program for it. Just remember who inspired you(!!!) 😉 😉
Unfortunately, I dont think such changes are possible, the contacts application (from nokia) uses nokia user interface model (Avkon) (which is anyway very strict in formatting data and fonts). It will require nokia to change the contacts application, (firmware upgrade). But as far as someone programming it, the only thing possible would be for someone to write contact application (but then why would you want to fill your memory with a duplicate application).
