DKU-2 driver installation problem
3 replies · 6,068 views · Started 26 January 2005
Hi guys...I came upon the following msg while installing DKU-2 driver "Quick Fix Q242004 must be installed on Windows 98 before running this setup, click ok to install Quick Fix". I proceeded but installation failed. The driver I got was from Nokia support site.
I'm using Windows 98, Nokia 6670 and DKU-2 cable.
Can anyone help?
Thks.
alot of things wont work on ur old windows 98, i think u should upgrade to windows XP.. but regarding ur problem, do a search on this.. there r many threads regarding this in the Nokia 7610 and 6670 forum.. what works for the 7610 should work for ur phone also
Note: Even if the USB cable driver might be installable on other Windows variants than Windows 2000 and Windows XP, it does not do much good, if you want to use Nokia PC Suite, which only installs and works on Windows 2000 or Windows XP and nothing else.
