MMS problem with SX1
2 replies · 2,424 views · Started 26 January 2005
Hi!
I'm experiencing a MMS sending/receiving problem with my SX1. I first got the MMS settings by sms from my provider, then from the siemens web site, and then I even entered all the settings manually.
I want to add that the MMS service is activated by my provider; i tried sending/receiving a MMS with my sim, using another phone and it worked. I also tried sending/receiving a MMS from another sim using my SX1 and it also failed.
The phone behaves as if it is sending the MMS ok (the outgoing arrow on top of the screen, which after a few seconds dissapears). I don't get any kind of errors.
I later found all the MMSs I tried to send stored in the mmstest folder.
Do you have any ideas what the problem might be? Did anybody experience something similar? I mean, can I fix it by myself or should I take it to the siemens people?
I forgot to mention, I have SVN 13 installed on my phone!
Thanks!
Dear
Do you install MsDriveE? Some times this program make problems during
send & receive of MMS.
Good Luck.
nope, i didn't install MsDriveE. These problems began right after I got the phone, before I could even install any software.
but thanks anyway!
