the other day my 3600 crashed and it wont boot now.. i just binks the nokia logo a few times and then turns its self off. i tried the 3+*+green power on format but it dosnt work. any ideas or am i screwed...
ps. if i end up being screwed any one want to buy a good 3600 with some software problems...
bugmenot wrote:the other day my 3600 crashed and it wont boot now.. i just binks the nokia logo a few times and then turns its self off.
How many blinks? Well iregardless, you would have to get that flashed. Had the same experience and a flash is the only solution i found effective so far.
i tried the 3+*+green power on format but it dosnt work. any ideas or am i screwed....
That doesnt work with 36xx phones. Only *#7730# in standby.
Just have it flashed and all will return to normal. I dont know how much it would cost there but here in the philippines it only costed around 9 dollars. Good luck. 😉
maby i should mail it to you to get it done... nokia here wants 100us to do it here
thanks for the quick reply
