I want vibration alert
3 replies · 2,394 views · Started 27 January 2005
I just bought my 6630, & i'm really happy with it, but once i start playing w/ it i found that i couldnt fine a way 2 enable the vibration alert altought i red it does has this feature.
Pls can any one help me on this because this is a very important feature for me! :frown:
if it dont have it! i'm gonna change it & get back to SE P900
RTFM
Go into profiles/select your profile you are currently using/select personalise/scroll down 6 steps and you will see 'vibrating alert' ON/OFF
Hey Buddy..
Cool down..don't blame anything if u don't know about it....... I wonder, u couldn't find the Vibration Alert option in ur mobile phone, u seem to be a new nokia phone user.. Go to Profiles->Select ur current profile->press button->choose Personalize->Now u should see options like Ringing tone, type, volume.etc...scroll down a little..and there u should see the option Vibrating alert, which is OFF by default, change it to ON...and thats it...and hey, don't forget to activate that profile, if u haven't..........Sorry for spoon feeding, but u seem to be very new to Nokia Symbian phones........
willbrady wrote:RTFM
thx alot willbrady,
