SmartMovie released for 7710
0 replies · 14,467 views · Started 27 January 2005
Lonely Cat Games have just released their popular mobile video player; SmartMovie w/ counterpart PC converter for the Nokia 7710.
(screenshot from the S80 version)
Features:
  • Standard AVI format, allowing you to preview converted files on your PC.
  • Uses downloadable video codecs, allowing you to compress and play back videos in your favorite format.
  • PC converter allows you to split video file into multiple segments, so that it fits onto your memory card, if not entire, then cut to more parts - you may watch your favorite video in parts, e.g. while traveling to work/school.
  • First mobile player which supports subtitles - allowing you to watch movies in different languages.
  • Friendly PC converter - preview videos on PC, select parts you want to convert, alter quality.
  • Supports DirectShow codecs, so you may use video codecs downloadable from the internet.
  • Very fast conversion, on standard PC conversion is 5x faster than video clip playback time. You will convert entire movie in just a few minutes
  • Bicubic rescale algorithm shrinks video to small screen size in best possible quality.
  • Adjustable quality parameters for video and audio streams, allowing to tune target video to your needs.
  • Customizable video Player (brightness, audio sync, volume , and more).
