What's the best screenshot program that uses MBM image format...?
4 replies · 3,397 views · Started 28 January 2005
What is the most highly recommended screenshot program for 3650 that makes use of the MBM image format? I prefer MBM format over JPG, but I've only seen the option to use MBM format on the N-Gage's included screenshot program (which is incompatible with the 3650). Any suggestions? Thanks.
Pepper Puppy wrote:What is the most highly recommended screenshot program for 3650 that makes use of the MBM image format? I prefer MBM format over JPG, but I've only seen the option to use MBM format on the N-Gage's included screenshot program (which is incompatible with the 3650). Any suggestions? Thanks.
I think MBM Stands for Multiple Bit Maps. What would you need an MBM file for? If you have powerlock and fexplore, Take a screen shot then use the screen shot in calendar as the background image, browse through the directory of power lock and it should be there as an MBM file. Thats the only way around that I know. Still,... what for? :con?
JPG format is distorted while MBM format isn't. MBM screenshots are the full clarity of the screen without defects, so as to take correct size of things on-screen, etc. To take a screenshot in JPG & convert to MBM doesn't do it, you still had the JPG format to begin with, it's distorted.
Thanks for the link, N/A, I wasn't aware Psiloc had a screenshot program also. Nice.
Pepper Puppy wrote:JPG format is distorted while MBM format isn't. MBM screenshots are the full clarity of the screen without defects, so as to take correct size of things on-screen, etc. To take a screenshot in JPG & convert to MBM doesn't do it, you still had the JPG format to begin with, it's distorted.
Yeah, IM quite agree with u and Im know what are u tolking about and as always I have solution 😃
U need wib capture (v1.11) that is the best screentaker ever.
( http://www.symbian-freak.com/quides/appguide/system.htm )
So all u need is to instal wib, run, Options=>Settings=>File type and choose BMP 24 Bits, it is non compresion bitmap format which u can converet into MBM without loosing quality :icon14:
hope this help
Cheers
