Save options contacts
3 replies · 1,872 views · Started 28 January 2005
Hi All,
I currently own a 6600 on which it's not possible to save all the contacts on the memery card (back up). Do you have this options on the 9500?
Draht
drahthaar wrote:Thanks,
Thing is, I tried that on my 6600. It backs up everything, but not my contacts...
Draht
How did you know? Have you tried restoring? What i use is Contacts Manager from agora and Contacts Transfer just in case the other one fails. It can back up your contacts or even send it via bluetooth / IRDA as one file. Compatibility wise that i dont know but it seems to work well with 36xxs.
