Hello,
I was wondering if anyone else has had the following problem.
I have installed the multimedia converter 1.1 at home under windows 98. Evertime I try and open any supported file type I instantly get an "Internal Error" message. Hence I can't convert anything. I have tried uninstalling and reinstalling but all with the same result. I've also tried the latest download from the Nokia site. However I've tried the same software at work and it works O.K. (Windows 95).
Its probably something nasy to do with my registry or a software conflict somewhere. However I thought I'd ask and see if anyone else has had the same problem and if so did they find a solution?
Andy
