Desktop suite via Buetooth A1000
2 replies · 4,317 views · Started 28 January 2005
Anyone had problems using the desktop suite via Bluetooth. Laptop says is can see the phone, phone has added laptop as a preferred device, both have the same passkey (I think) but when I try and "connect" via the desksuite icon on the phone it just sits there for ages then said it couldn't find the laptop.
Any ideas?
packerm wrote:Anyone had problems using the desktop suite via Bluetooth. Laptop says is can see the phone, phone has added laptop as a preferred device, both have the same passkey (I think) but when I try and "connect" via the desksuite icon on the phone it just sits there for ages then said it couldn't find the laptop.
Any ideas?
It would be worthwhile checking your Win XP Firewall ( presuming you have XP ) and also confirming that on the A1000 ( and mrouter on PC ) you have selected Bluetooth as the option for connecting to the desksuite
have you terned on the blue tooth on the phone and made it not hiden in the blue tooth options in control pannel
