I need more "BOUNCE" for 3650
30 replies · 22,121 views · Started 28 January 2005
Hi
I have finished levels 1-11 of Bounce.
Where and how do I get more levels for the 3650,in UK.
Please explain as if to a computer/Symbian novice😊
Thank you Chris
:con?
here u go, i hope they are legal as i found the link to them on the forum but it was dead. paste the files using FeXplorer, if u have installed bounce onto mmc then E and if phone then C, system>apps>bounce>levels and paste there, finish the 11th level and move on till the 21st 😊
Attachments: Bounceaddonlevels.zip (23 KB)
Did you understand that reply you got about the bounce extra levels?? If you did please let me know!!
Cheers P
yea... copy the extra levels into the dir in the phone were the other level files are with Fexplorer
system>apps>bounce>levels is were other level files kept
The zip file is just 23.7KB, not 237KB?
BTW does anyone know a good place to get FExplorer? Thanks heaps!
I'll explain in more detail:
1. Download the level pack zip file from here. Unzip it. You should have 10 files in the format "level.0??". Use PC suite to transfer the files to your phone's root folder in C: or E:.
2. If you don't already have the software fExplorer, get it now. Try looking for it from google. After you get the sis file, use PC suite to install it on your phone.
3. Open fExplorer from your phone. Locate the folder "system\apps\bounce" from either C: or E:.
4. In that folder, create a new subfolder called "levels".
5. Go to the root folder where you transferred the 10 level files, move them to the "levels" folder you created.
6. If you have already completed level 11, now you should be able to play level 12 when you open the game.
Guys & gals, I've completed all 21 levels, i.e. finish the game unless there is a level 22 released (I doubt it). I tried to grab all the items I can get, and have a score of 319800. The 2 place where I cannot grab all items are:
1. level 11, where a gold is surrounded by a square of deflators,
2. level 17, where 12 bubbles and 10 golds are in 2 chambers close to the bottom, and there is no way to enter these chambers.
If I have 1 more gold, I would have 320000, a very nice number for a perfect score. So I highly suspect that I should have got that gold in level 11. Anyway just ask me if you stuck in anywhere. I should be able to help. I might write a detailed walkthrough on level 21 if anybody wants one. It was fun.
List of scores I got from each levels:
Level Score Total Hoops Golds Balls Points (500H+200G+1000B) (Extras)
1 8700 8700 5 1 1 2500+200+1000=3700
2 11600 20300 8 3 2 4000+600+2000=6600
3 11700 32000 7 6 2 3500+1200+2000=6700
4 12700 44700 9 6 2 4500+1200+2000=7700
5 13200 57900 10 6 2 5000+1200+2000=8200
6 12000 69900 8 5 2 4000+1000+2000=7000
7 14100 84000 11 8 2 5500+1600+2000=9100
8 13900 97900 11 7 2 5500+1400+2000=8900
9 14200 112100 14 6 1 7000+1200+1000=9200
10 15600 127700 12 8 3 6000+1600+3000=10600
11 16900 144600 15 12 2 7500+2400+2000=11900 200
12 14000 158600 14 5 1 7000+1000+1000=9000
13 15300 173900 13 14 1 6500+2800+1000=10300
14 14900 188800 15 7 1 7500+1400+1000=9900
15 14700 203500 15 6 1 7500+1200+1000=9700
16 14900 218400 15 7 1 7500+1400+1000=9900
17 18200 236600 20 11 1 10000+2200+1000=13200 14000=10x200+12x1000
18 18000 254600 20 10 1 10000+2000+1000=13000
19 19400 274000 20 12 2 10000+2400+2000=14400
20 21100 295100 19 18 3 9500+3600+3000=16100
21 24700 319800 19 31 4 9500+6200+4000=19700
Edited:
In fact the highest score so far should be 331800. In level 17 I managed to get the big ball into the left chamber of 12 bubbles to get 12000 points more. I could jump over to the right chamber and take the 10 golds of 2000 points too but then the big ball will be stuck below forever until you kill off all remaining lives. So after getting the 12 bubbles the ball must be suicided to proceed the game. Level 17 and after should read:
17 30200 248600 20 11 13 10000+2200+13000=25200 2000=10x200
18 18000 266600 20 10 1 10000+2000+1000=13000
19 19400 286000 20 12 2 10000+2400+2000=14400
20 21100 307100 19 18 3 9500+3600+3000=16100
21 24700 331800 19 31 4 9500+6200+4000=19700
I've posted the walkthrough in a new thread here:
http://www.allaboutsymbian.com/forum//forum/thread/36317/
Instead I'll post a link for maps of the levels. It's for series 80 (eg. 9210) by a German/Swiss site. I'm sure you'll all find them very helpful:
http://www.aikon.ch/div/bounce/losung.html
Edited:
Fixu has worked incredibly hard to produce his own 21 s60 maps by taking thousands of screenshots and pasting them altogether. Go to this thread which links to his site:
http://www.allaboutsymbian.com/forum//forum/thread/37151/
i was wondering if any body could help me get passed level 12, i am stuck on the first bit and the maps dont help either, i am using a nokia 6260, cheers
chris_0000 wrote:i was wondering if any body could help me get passed level 12, i am stuck on the first bit and the maps dont help either, i am using a nokia 6260, cheers
I use a 6260 too! The maps are v. helpful, just a little bit different here or there.
For level 12, when you go up to the "V" shaped pool, stand on the edge, jump up vertically to gain some height before diving into it and quickly move left, you'll get past those spikes. If that's where you got stuck.
Keep asking here. You'll get help.
Hi Bouncer11, I'm trying to install the extra levels of bounce on a 6260 and I'm struggling. I got Fexplorer, transferred files to via nokia pc suite to C:
But dont understand the next bit -
when I open my main menu and scroll through I have a tools menu and the add on levels show in there but not the menu path system\apps\bounce
I am losing the will to live with this!!!!
Cheers Patti
hi guys,
excuse me, here everyone says they've been using a kinda map or smth... where do u get the map for bounce???
i use 3650...
Patti/priley,
When you open Fexplorer, pressing left arrow you'll go to the upper level folder and right arrow to a subfolder. So first go to C: drive and then press right, scroll to "system" and press right ... until you are in "C:\system\apps\bounce" (that's the folder in your phone, not your PC's one ^_^). If there is no such folder, go to E: drive and try the same thing. Then use the menu commands to create a new folder called "levels". Go back to the place with the 10 files, cut & paste them to the "levels" folder one by one (the shortcut for "cut" is "4", "paste" is "7" I think).
BTW if you go to Z: drive (phone's ROM) and go to "Z:\system\apps\bounce\levels"
you will find the level files for the first 11 levels.
Hi guys,
I'm a newbie in this forum, and i need some help from y'guys for my nokia 3660.
I played Bounce V4.16 and stucked in level 9, and when i refered to the maps y'guys provided (the link) and it is diffrent from what i'm playing now..
My question is:
a) where do i get the maps for my Nokia 3660, Bounce V 4.16? (i downloaded this version from Nokia Website)
b) can i apply the add-on level files to my version? (the zip files y'guy provided)
thanks for y'guys help!! 😃 😃
Have you figured out how to install on a 6260 running into a similar problem
was curious if you had it working yet
please let me know [email][email protected][/email]
rgds
Richard
QUOTE=priley]Hi Bouncer11, I'm trying to install the extra levels of bounce on a 6260 and I'm struggling. I got Fexplorer, transferred files to via nokia pc suite to C:
Open from your phone. Locate the folder "system\apps\bounce" from either C: or E:.
Cheers Patti[/QUOTE]
Eason, those s60 maps were done from gameplay (by Fixu?) and I must say I am amazed by their quality and effort from the creator. However they didn't tell the whole story and at the moment I can tell at least 2 "secrets" that weren't shown there:
1. In level 9, above the red and blue platforms up in the middle part, there is a "secret cave" in the wall. You have to use anti-gravity to fly into it (no reward though).
2. In level 17, the maps only show the "O" of 6 bubbles and the "E" of 10 golds, but there is in fact a "J" of another 6 bubbles at the left side of the "O". Of course you have to get into the left chamber to discover that. It's very tricky, and if you read my "walkthrough of level 21" (posted in this forum somewhere...) you will know how I did it. You get an extra 12000 points too so very rewarding indeed.
The max score I know is 331800. Just wonder if anybody knows if it could be improved...
Thanks Bouncer11, i will try to look for it. Do you know where is the "bouncedit" located? I found it but that is for series 40..i need series 60. 😊 Maybe will try to do my own map.. 😃
At the moment I know of 2 existing level editors, one for s40 (bouncedit) and another one for s80 (forgot the name, but done by some German programmers). Nothing for s60 yet. Also, I'm pretty sure there are only 21 levels for s60. No news of new levels coming out...
Hi bouncer11,
finally got the extra levels working! Had to complete 1 - 11 again as I deleted them when I was trying to install the new ones.
Thanks for you help
Patti
vly21 wrote:Have you figured out how to install on a 6260 running into a similar problem
rgds
Richard
Cheers Patti
[/QUOTE]
Hey dear,
Do not get depressed by such a small problem.
I have a NOKIA 6260. I also faced a lot of problem installing the bounce levels initially...
I'll tell you what to do...
You’ll definitely find either "C:\system\apps\bounce" or "E:\system\apps\bounce" on your phone. Here is what you need to do
Go into above mentioned directory.
If you have a folder named "levels" then that's fine, otherwise create one with that name.
Now transfer the level files to your phone from PC by whichever way you want.
I transferred it via BLUETOOTH. So it came as a message.
If you are having difficulty finding these files after you have received thm on your phone, then here is what to do:
Go into the main (first) screen of the FExplorer.
Go into INBOX if ou got it via bluetooth.
If you find the level files ... well and good. Move them to the levels folder which you have created.
If you do not find those files or you find only some files out of what you transferred... do move these files from here to the levels folder.
applicable for all
Now do the following.
Go to the main screen of FExplorer.
Just highlight to C:
Now in the options menu go to file/find
Type in the name "level.0*” whichever level you want. You’ll see it displayed on your screen. Again go to options/file/goToPath. Now copy the file from here and paste it to the levels folder which you created.
I hope it helps. Do the same for all the 10 files. Do write to me at [email protected] if you are successful or if you still face any problems or you need the files, I’ll mail them to you.
Great assistance - thanks. Worked a treat and simply too if u follow the instructions given. 21 levels now available so ta.
Desertbear
Greetings Dear Experts, who have finished level 17, Please help me what is the exact trick you need to stop falling into the pit with air blowers that puts you in a difficult situation , please share your expertise , the ball always gets pricked by thorns. Is there any trick that works fool proof please guide me.
Akanksha
I've got nokia 7610 i tried installing it but it says unknown format i tried changing it to jar , jad and dir format but still not working:con? . CAN ANY! HELP ME PLEASE!!
