wav ringtones for QD
1 replies · 2,951 views · Started 29 January 2005
hi all! can anyone please explain how i can use wav files as ringtones? also i heard you can ogg files as ringtones if you have the ovcontroller, is there a particular version for the ngage? i tried installing the controller for the 6600 but the phone couldnt install it. thanks in advance.
My wav files are in this format: PCM 8,000kHz, 8 Bit Mono. They work fine for me like this, don't sound too bad either - you can convert any files that don't work with the Sound Recorder that comes with Windows (File\Properties - then click Convert Now . . .).
