i bought IM+(registered version), but i cant connect 😞((
what i need to do?
i'm in moscow.
Beeline, i have WAP and WAP over GPRS connection. what i need to make? and i ve downloaded browser WebViever and the same story it doesnt work...
Why? Please right down all conditions and all setup instructions.
Both Webviewer and IM+ do not work with WAP you need regular internet access! Contact your Network and ask for a GPRS account with internet access not only WAP access! Try your regular ISP settings that u use for the PC!
when i m connecting with Web Veiver it says that: Status = -20015!
What is it?
could you right down all your setup conditions?
how to setup GPRS basicly?
Do you mean Wap over GPRS"?
[quote="igogo"]when i m connecting with Web Veiver it says that: Status = -20015!
What is it?
Do you mean Wap over GPRS"?[/quote]
I dont realy know that the -20015 but it does really not matter! They do NOT work with WAP! As I said you need regular Internet Access!
Try creating an Access Point with the settings you use for your PC
Dialup Number
Username
Password
Use GSM DATA and Analogue call!
Try to use this access point instead of GPRS to see if it works! If yes then you could use thease or Ask your network to convert WAP GPRS to Internet GPRS account!
but i could send multimedia messages over GPRS, anybody could send me one???? make a pic and send to me?
+79032743242
Go to Access Point
Create New Access Point - using default
You Must now Internet access point setup for GPRS ie "internet"
Data Bearer -GPRS
Gateway IP adress 0.0.0.0
You must consult your service provider if there is a need of user name and password, if not just leave it blank
* Your problem before this is because your access point is setup to use MMS gateway but for GPRS it does not require this 😃 😃
