Data cable can't connect to pc
1 replies · 1,996 views · Started 29 January 2005
pls hlp!
my n-gage's data cable can't connect to pc (w98-wxp) and the earphone's logo is always show.
pls chat with me in yahoo! msgr nick: rulirahm
thx u 4 ur kind att
ruli
Dear Friend,
I Have A Crude Solution For Ur Problem. I Had The Same Problem And I Just Solved By Doing The Folowing Procedure.
The Procedure Is Very Simple. U Just Have To Push Ur Earphone Pin With Force In The Its Slot. And Then Pull Back. Tried One Or Twice. Hopfully It Will Solve Ur Problem.
Thanks.
