Application Question
3 replies · 1,969 views · Started 29 January 2005
Hello,
Can I install applications from N6600 to N6630? I want to install some games and iRemote. I heard that only SOME apps. from 6600 can be installed on N6630, if that is true should we make some list with what apps work on 6630? 😊
Thx 😉
e.bug wrote:Hello,
Thx 😉
as i know the iremote works with innfrared port and this is not included in N6630,only bluetooth and cable capability 😃 and try to search in topics,beafore you ask,because there is an list of applications which are working properly and which of them not 😃
Fidelko wrote:as i know the iremote works with innfrared port and this is not included in N6630,only bluetooth and cable capability 😃 and try to search in topics,beafore you ask,because there is an list of applications which are working properly and which of them not 😃
Yeah.... i forgot about the iRda thing 😃. Thanks, i will search 😊
e.bug wrote:Yeah.... i forgot about the iRda thing 😃. Thanks, i will search 😊
never mind... next time try to search application which dont need and iRda thing
