Hotmail? Does it work on 7710
5 replies · 3,028 views · Started 29 January 2005
I have all standard applications on my 7710. Need to check my hotmail while I'm on the go. Anyone know any suggestions as I don't know how to configure it or something but when I connect to GPRS, it just says connecting and I guess it just never connects. No luck at all.
Please shed some light!
Thanks!
Yes, Hotmail works fine. In fact, I'm looking at it now on my phone. Only thing is it takes quite long to load. And I'm on EDGE. GPRS would be quite a bit slower.
HI Kengsim, i don't know if I have EDGE or not. I'm using Orange from Hong kong. Also i tried going into my hotmail but it keeps saying that my browser has disabled cookies but it's really enabled under the settings! I can't seem to get through the login !!! Please help!
Thanks my friend!
kengsim wrote:Yes, Hotmail works fine. In fact, I'm looking at it now on my phone. Only thing is it takes quite long to load. And I'm on EDGE. GPRS would be quite a bit slower.
Kengsim, are you a DiGi subscriber? What do you think about the subscription rates - Value for money?
If you are a heavy data user, sure. Good thing about unlimited is that I never have to worry how long I spend browsing. I just connect and surf and download my emails whever I want. RM99 is worth it.
