Turbo MSN is a powerful MSN client, supporting Nokia 3230/6260/6600/6620/6630/6670/7610, Panasonic X700, Samsung SGH-D710, and other Series60 devices running Seires60 2.0 onwards. Main features include:
Contacts management: add/remove/block/unblock contact, add/remove group
Complete emoticon support
Support English and simplified Chinese UI
Presence status support
Sound alert for incoming message
Save chat history to file
Support unlimited chat sessions
Instant message with two or more persons
Send SMS/MMS/EMail
Full unicode support
Download the try version from: http://www.mobileinttech.com
or purchase at:
http://www.handango.com/PlatformProductDetail.jsp?productType=2&optionId=1_4_2&jid=3CDCB558XCD1FADAC379FA6B1XBC969A&platformId=4&siteId=1&productId=146632§ionId=0&catalog=20&txtSearch=turbo+msn
or
http://www.symbos.com/live/product_information.php?ApplicationID=1675
frogking wrote:Turbo MSN is a powerful MSN client, supporting Nokia 3230/6260/6600/6620/6630/6670/7610, Panasonic X700, Samsung SGH-D710, and other Series60 devices running Seires60 2.0 onwards. Main features include:Contacts management: add/remove/block/unblock contact, add/remove group
Send SMS/MMS/EMail
or purchase at:
or
I don't understand what is so special about this Turbo MSN,
AgileMessenger from www.agilemobile.com looks much much more
professional and nicer, and the best part is, it's free!!! 😊
AgileMessenger support most smarticons.
Because Frog King is just trying to plug a version of msn he obv makes money from.
anyone had success running agilemessenger on a 3230? I ran the v3.0 one (filename AgileMessengers60.sis) and it installed to the phone ok (using either phone mem or mem card) but wouldn't run. If you started it, the screen would go white and then return back to the main selection menu...
any ideas?
Same here, the agile messenger didnt work. The MSN turbo worked perfect, sad that its only a trial.
the MSN client on my spv c500 is fine, but that's cos it's a microsoft based OS - turbomsn worked fine on my 3230, but I wasn't 100% convinced by it and imo it's not worth the �20 or however much it is *if* agilemessenger can be made to work on the device.
Am determined to get MSN Messenger workin on my 3230 but am having great difficulties... Got TURBO MSN but am sure its something to do with the PRESENCE settings... anybody know how to set these up?
I got turbo msn on 3230 when my memory card was empty it worked great, the look of it i liked alot. And started working straight without setting up any settings. After i installed alot of different software and it stoped working at all. So i figured it was conflicting with some software.
Btw i got agilemessenger to work on 3230, but it has to be only version 2.1. Works fine that way.
mine agile messenger works fine and i hav the oldest firmware i got it a weak ago 3230 compatible agile messenger is there can be downloaded from agile.com :icon14: 😎 or from down
