which web browser?
4 replies · 1,745 views · Started 30 January 2005
lp4u wrote:which web browser do u recommend me guys? the nokia web or opera and y?
thx
i think that the preinstalled browser is good enough and this is the reason why there is no opera on the memory card,like in some other Nokia Series 60 devices... its supporting wap,html,and java script,its fast and good enough... 😃
fdxd wrote:Opera is really good but you have to pay for it beyond the trial. Worth trying out.
yes,or he can try the netfront browser 😉 but people from nokia may think,thtat the preinstalled browser is a good enough choice 😃
Fidelko wrote:yes,or he can try the netfront browser 😉 but people from nokia may think,thtat the preinstalled browser is a good enough choice 😃
I would advice you to try out the other browsers than the original Nokia one. I use Opera on my 7610, and compared to the Nokia browser Opera is quite a bit better (both faster and easier to used, and renders pages better). I also recommend using the Opera accelarator, which is a tool that compresses and optimizes web pages before they are sendt to Opera. This saves quite a bit of monet if you have a "pay per mb" phone subscription...
By the way, if you buy Opera - do this through the Nokia software download pages:
http://www.softwaremarket.nokia.com/DRHM/servlet/ControllerServlet?Action=DisplayDevicePage&SiteID=nokia&Locale=en_US&Env=BASE&resultsPerPage=10&deviceID=6630
Buying Opera only costs 9.99 Euro through these pages! Thus Opera is cheaper than Netfront 3.2!
Info on the Opera surfing accelarator: http://www.opera.com/products/mobile/accelerator/
Good luck!
