Hello,
I've also a Nokia 3650 and I want to know how much memory can I put into my phone (MMC card). Nokia says, only 128MB MC cards are supported. Is it possible to put an 1GB MMC card into my phone.
Furthermore I tried to play a mp3 song with my phone with the tool "ultra mp3". But if I plug the headphone into the socket (with a 3,5mm --> 2,5mm audio adapter) the phone plays the song always about the speaker and lets the headphone unused. Can anybody help my for this problem. Is there a special headphone necessarily.
(If I plug the adapter into the socket the phone shows me in the display, that a headset is plugged in).
Then, I've another question. If is possible to switch on/off the backlight of my phone if i play a songfile and how can I do this. I need a special program to compose a song?
kind regards
gravity
gravity wrote:Hello,I've also a Nokia 3650 and I want to know how much memory can I put into my phone (MMC card). Nokia says, only 128MB MC cards are supported. Is it possible to put an 1GB MMC card into my phone.
yeah, Im try up to giga without any problem...
Yeah, u need a special headset beacuse usual headset phone dont recognize as right accesory...
You can turn up backlight on with torch application, lights will turn off by self!?
Well, u can try but I suggest u to convert mp3 songs, use any prog with lame encoder, u dont need more than 64kbps, mono offcourse, beacuse phone cant play stereo!!
Hope this help
cheers
