My wife and i both have 7610 , i install games, ringtones on mine etc, my wife installs nothing and changes nothing ,just like out of the shop all the time, i have formatted my memory card to remove all games etc as i thought this was quicker but not realising i would lose the pre installed stuff , so i backed up my wife phone with pc suite as i was going to reinstall it on my phone , but when i put her sim card in my phone it asks for a lock code , manual says 12345 but this wont unlock the phone , it does not work on my or my wifes phone and we have definately not changed the lock code ,pin code yes but not lock . Can anyone please assist :con?
7610 lock code help please
maybe ur operator can help u with the lock code, if u havent changed it then it should have been 12345.. if the operator cant then u have to get the phone flashed
try 00000 or 11111 ok this might work or call your servise provider such as orange / t - mobile etc they might give you an solution ok dont wory this is a simple matter
try this it will work definitly
The soft-format code for Series 60 phones is *#7370# . You enter this code as you would enter a phone number in the Phone application. It performs a format of the Internal drive - All data will be lost if you use this feature.
The method of performing a hard-format, i.e resetting it completely to factory defaults and removing all data, is as follows:
+Switch off the phone.
+Hold down the following three buttons: Green (call answer) button, * button, and '3' button
+While holding these buttons, press the power button and switch on the phone
+When the message 'Formatting' appears on the screen, release all of the buttons
+Note that you shouldn't switch the phone off or remove the battery when +performing either of these operations, and it's advised that the handset has a +reasonable amount of battery charge before performing a format/reset.
call me if it works on 07854 781 946
