my n-gage usg data cable can't connect 2 pc, why?
USB data cable problem!
Hard to say with so little info to go by.
Broken phone?
Broken cable?
Broken PC?
Wrong OS on PC?
Bad OS on PC?
Badly configured OS on PC?
Sunspots?
So, how about some details?
What, exactly, happens when you connect (including any and all possible error messages verbatim as you see them)?
What operating system is on your PC (if it is Windows, what version)?
Does it have support for USB mass storage devices?
Do other USB devices work (such as USB "memory sticks", USB card readers or USB hard disks, a digital still camera)?
Here is the story, sorry i forgot to tell.
First, i've got my phone error (couldn't start up, maybe cause of wildskin). Then i take my phone to the technician and reinstall my n-gage (without mmc). After that, format my mmc using xp-pro-sp2 7 times (using data cable). My bluetooth s/w n drivers is still on my xp and bluetooth usb dev is pluged to my usb pc (i'm not reinstall the s/w n drivers). 2 days after that, format again my mmc , the data cable is still work. After that, my xp can't detect my mmc using data cable and my xp displaying errors msg : (usb dev not recomended, try to unplug n plug again ). I try another device : digital camera and the dev is using data cable to. same.... 😞
pls hlp!
N/A wrote:Hard to say with so little info to go by.Broken phone?
Broken cable?
Broken PC?
Wrong OS on PC?
Bad OS on PC?
Sunspots?
I'v got a serius problem not with the XP, same here USB cable Don't work with my 512 MB MMC (A-data), i tryed to format it from windows but i formated it in a bad format .... by mistake, after that i format it with MMCmedic and phone format .... and now i cant conect trough my usb cable with any pc's , i reflashed 2 times the phone .... the USB port on the Phone works but when i'm using the 512 MMC no CABLE pls help !!!
have u check ur mmc for corrupted? http://www.symbian-freak.com/forum/viewtopic.php?t=108
Maybe could help 😊
rulirahm wrote:my n-gage usg data cable can't connect 2 pc, why?
fungsi card reader pada n-gage saya hilang/ tidak terbaca saat dikoneksikan pada pc, apakah masih bisa dibetulkan?
mohon saran/bantunnya terima kasih
[email][email protected][/email]
purworejo-jateng
Buka link diatas atau saya ulangi lagi:http://www.symbian-freak.com/forum/viewtopic.php?t=108. Mungkin anda harus daftar dulu di forum tsb atau bisa lihat di web saya http://geocities.com/rulirahm/s60. Ambil file '7pm2004_demo.zip' beserta manualnya 'mmc_7pm-HOW_TO.zip'. Dua itu saja karena kasus seperti ini rata-rata disebabkan oleh memory card saudara corrupt. Apakah anda pernah memformat mmc sdr dgn menggunakan windows(xp)? Hal tsb tdk boleh dilakukan. Nah, selamat mencoba
