Copy phone's contacts to SIM directory
3 replies · 4,600 views · Started 30 January 2005
rulirahm wrote:How to copy the phone's contacts to SIM directory, App? Can I know what the app is?
😊 Than U
Are u tray Oxygen!?
www.symbian-freak.com
The built-in Contacts app does it, but you have to do it one by one (select a contact, open, select a number, hit "Options" and then the obvious option for that in the menu).
Are u referring to N-gage QD hp? Ok wat i did was go to Tools > SIM Direct > Select > Mark All > Copy to Contacts.
Hope tis helps.
Cheers,
Loonshi
