The Sendo X Song of Death
10 replies · 6,503 views · Started 30 January 2005
In recent weeks, my trusty Sendo X has begun emitting what I call "The Sendo X Song of Death." That's the sound it makes when an application crashes -- usually something called the Main App.
This has been happening so frequently that my parrot now sings the Sendo error alert throughout the day -- in perfect pitch, I might add.
Has this been happening to other Sendo X users? I've curtailed using the phone until the next firmware release.
Thoughts appreciated.
It happens to me atleast once or a MAX of twice a week but definately not more than that. Everyday sounds like alot, maybe something is wrong with yours? Try a full erase and reinstall your apps maybe
Which apps do you currently have installed?? I never see that crash, so it may be an interaction with what you have installed....... Messus?? If you give us a list too then maybe it will be obvious!
Well, I've uninstalled all my add-on apps. Not sure if the problem is solved, though. And my infrared is still not working (hasn't for a couple months now).
How does one do a master reset?
Interblat wrote:Well, I've uninstalled all my add-on apps. Not sure if the problem is solved, though. And my infrared is still not working (hasn't for a couple months now).
Master reset is the same as for when you have loaded new software:-
Hold down the '5' key whien you turn the phone on & then confirm to clear the memory - this will wipe out all your contacts data etc.
If this doesn't solve your problem then you might want to reflash the firmware & then do a master reset
jarold wrote:Master reset is the same as for when you have loaded new software:-
Aha! Well, actually, I have done that. But the infrared still won't work. I have solved the "song of death" problem, though. But I'm afraid I might have to retire my X.
please help me in my sendo x infra always on its light always on when i placed new firmware 1.198.8.2 in sendo x after that my infra turned on and my battery down in 5 hours it is a bug in this firmware i donot have old firmware please tell me what i do now please help me i m from pakistan and my email is [email][email protected][/email] please email me my name is umair and number 00923455228166.
Well I Receive this error message so many times a day that I now assume this is what Sendo Was Made For...to Give us this message everytime we want to use it.
