.sis files usable on an SX1???
2 replies · 3,617 views · Started 30 January 2005
Hey all, just bought a new SX1 and want to use themes on my phone as I have on my 7610 and 6600. Seems the SX1 doesn't support skins. Is there an app to enable this or am I stuck?
Cheers,
Robfa3
robfa3 wrote:Hey all, just bought a new SX1 and want to use themes on my phone as I have on my 7610 and 6600. Seems the SX1 doesn't support skins. Is there an app to enable this or am I stuck?
Cheers,
Robfa3
Yes, unsis with unmakesis, and then edit the mbms with mbmwizard, save the images and remaked .sis with themerizer.
1. download the theme you want (for example: http://www.symbianthemes.com/navigation.php?page=showitem&type=1&id=175 )
2. unsis the .sis-file with "UnMakeSIS" (attachment)
3. open the extracted folder with the "MacOS.mbm" and "MacOS.skn". You wont need MacOS.skn later, you can delete it.
4. put the MacOS.mbm in directory youve installed mbmtool (attachment) and open it with the mbmtool and extract the background-files. normally there are at the beginning. you must put together two parts so that the final image has a heigh of 208 pixels!
5. open themerizer ( ftp://hive.gmtmy.com/pub/Themerizer_v3.141fix.exe from oslik.ru - forum ) and make your own .sis-file that you can install on your phone without problems. but if you have put all your images into themerizer you must save the .sis-file into the dir where youve installed themerizer. otherwise it wont be saved.
