hidden apps?
4 replies · 1,587 views · Started 30 January 2005
i bought a 256mb rsmmc with preinstalled apps. I went to the App Manager and found that there are more apps listed than those appear in the Menu. What might be the problem here? Is there a way fix this or install them? B/c the space used in the rsmmc is like 170mb!!
that does happen.. the little apps u found in the manager but dont see in the menu are actually small parts of the bigger apps, like wordmate and slovoed etc.. u will have to remove the apps to get space! they have i dont know what versions and all crap
zainman wrote:that does happen.. the little apps u found in the manager but dont see in the menu are actually small parts of the bigger apps, like wordmate and slovoed etc.. u will have to remove the apps to get space! they have i dont know what versions and all crap
sorry, but i didnt get what u mean by "u will have to remove the apps to get space". do you i remove those small parts or the bigger apps?? if the bigger apps, how would i know which small parts belong to which app?? :con?
what i did was remove all the little bits with large sizes and weird names and then remove all the big apps with proper names.. and i got space!
