not connected
1 replies · 1,435 views · Started 31 January 2005
have p900. ive installed pc suite on to pc. have put the usb and shows its connected. when i click on the icon on desktop says not connected. also wont let me enter a phone name on the select phone option.can you help me please :icon4: :icon4:
Hi Stevie,
I have experienced the same problem as you describe.
The solution at least for me was simple - simply turn the module off and then on again. Now it should work as supposed.
I hope this helps.
/ Johan
